Post by guadixman on Jan 19, 2010 8:19:05 GMT
Andy, you say you have added damping and tightened the trannies and that though the hum is reduced it's still there.
Well have you tried this; loosen the fixings and, cables permitting twist the trannies relative to each other. You will need the amp on to tell if there is a difference. naturally take all safety precautions - you can in fact buy special rubber gloves and as always keep one hand in your pocket ( but not wrapped round your nuts). Should you get a 230V 'touch' it won't arc across your heart.
Post by andy on Jan 19, 2010 9:19:01 GMT
Not sure I want to know about your 'special rubber gloves'!!
But you have a good idea there, i guess somthing about the magnetic feilds crossing? I should be able to give each a slight twist, there is not much play though.
I will try that one next weekend when i can get away from my 7 month old for two mins!!
Post by PinkFloyd on Jan 19, 2010 10:20:33 GMT
Sounds like good, safe advice to me
Post by andy on Jan 19, 2010 11:07:35 GMT
Did once see a chap 'checking' a camlock, about 600 Amps 3 phase, whilst stood in a puddle. He is still alive. though there was a funny smell when someone shouted that it was live.
Maybe he needed some special rubber gloves?
Post by Deleted on Jan 19, 2010 11:38:18 GMT
Did once see a chap 'checking' a camlock, about 600 Amps 3 phase, whilst stood in a puddle. He is still alive. though there was a funny smell when someone shouted that it was live. Maybe he needed some special rubber gloves? Andy Maybe his helpers needed surgical gloves after he shit himself ? Alex
Post by guadixman on Jan 19, 2010 13:44:41 GMT
These gloves are a bit on the large size but will protect you from getting a wack.
I was working on a valve amp once when a friend of mine called round and I was wearing them (there was 650V in there).
As soon as he saw them he said "WOW if my friends at the Fetish Club saw them they'd have to go and buy some immediately.
When I asked him what they would be used for he said "definately not for testing valve amps" - I would tell you what they would be used for but you might just have had your lunch.
Post by andy on Jan 28, 2010 10:27:28 GMT
Right first time with photos, so here goes! inside of the power amp (obviously). Closeup of one of the humming trannies Since then i have added the rubber O rings between the metal washer parts.
Post by robertkd on Jan 28, 2010 11:08:15 GMT
andy, you do know why they were humming don't you,... because they couldn't remember the words
Post by andy on Jan 28, 2010 11:10:54 GMT
wondered when someonw would say that........
