OK so I was weeding through my "stash" of Digital Audio chips and what did i come across ?
A good selection of LDO chips at the bottom that I had forgotten about along with a little "baggy" of parts for a pair of Jung "Super Regs".
The opamps in the baggy are AD797s though I may toss them in favor of some newer OA devices I have though will take a bit of pouring through the data to find which.
anyway a mini rant :
Older digital chips had actual PINS and did not seem so damn fumbly/girlie to work with as do the new parts plus the voltage standards have sgifted away from 5V (at worst +/- 5VDC) to 3.3 VDC and all because the main market is battery operated portable devices.Many of the older parts not only preclude a teeny tiny high desnity pcb footprint but would snack on batteries as if no more than finger food to pass time while waiting for a serious meal (real POWER).
cool.I know the "why" of it and ralise where consumer electronics are headed but stilll makes things no easy task when you try to meld the two into one and a high SQ the goal.
firstly mixed back DIP/SOIC devices makes for a very schizoid layout,one loaded to heavy/bulky on the DIP end,tiny and "busy" on the other.
Second.the standards change from +5 VDC to +3.3 VDC means you MUST use more than one regulator : one for the 5 Volt section,one for the 3.3 volt section and they both must fire up at exactly the same time or be sequenced properly for proper circuit operation (why there are "control" pins on the newer V-Regs
) rather than supplying the entire circuit with a single clean power source that is bypassed an decoupled right at each devices Vdd and Vcc pins.Yes the analog section usualy needs an even higher voltage for good performance and high output levels but to be honest if the initial DC buss is really clean and the Op Amp properly bypassed and again decoupled right at the power pins regulation is not
essential so can be fed with the "raw" DC source before going to any regulators so in essence will get the highest current feed being first in line and will be isolated as well as can be all things considered from the digital power buss through the combination of local decoupling and the digital section v-reg providing a "dam" to digital power buss.At least it sounds good in my head and until someone shoots holes in the theory i'm sticking with it
Those who are queesy about unregulated analog stages need to think about how many unregulated battery powered audio devices there are so the only difference would be clean battery DC vs. possibly dirty AC and if the preceeding power buss is a proper Pi-filter and the AC feeding it clean,if the rectifiers have hash suppression i see no reason why the PSRR of modern op amps is not at LEAST the equal of your average discrete stage WITH a regulated power supply !
Anyhoo..........
Have no choice but to bit the bullet and go with two V-Regs so it looks like right now it is TI REG101 Fixed 3.3 VDC @ 100mA for the USB section and the Jung Reg at +/- 5 VDC for the DAC chip digital and analog sections all fed from my external "Power Station" (stole that one from Audio alchemy but it fits dammit
) that pushes out +/- 16 VDC, and +12 VDC,all way too high without more CRCRC filter stages to hit the regulators with the differential between the "Raw" DC and the "Regulated" DC being so wide the teeny tiny chips may eat themselves while trying to cast off the exess voltage which would be be converted to heat yet with no heat sucking area large enough to wick it off (i.e. a heat sink big enough translated from rickanese to english
Hate to do it,means larger final caps than I would like to keep the raw DC feed at a lowish impedance but I don't make the rules (rarely follow them either
) so now it is a matter of placing the order for the MIA parts then putting theory to rest so I can nail down the basic architecture and begin the long tweaking process.Means "plain brown wrapper" passive resistor IV to start (will have an output in the millivolts range so will need me to use one of my gain stages to up it),then the "all passive" SINC correction,then various active IV stages then.....
Once I get the sound "ballpark" satisfactory I will fk around with trying various V-Reg methods on the TDA side and reclocking to see if it is just over complicating the already complicated,changes just to do them (FOTM thingy) or just change,or if the additions truly are an upgrade in
actual SQ.
One of my problems with something like this is i never seem to stop "fiddling" with it instead of just closing up the GD lid and bolting it down,accepting the "thing" for what it is and enjoying it on that level.
Anyone who followed my years long Szekeres Amp optimizing path,a path that began at Headwize then on to Head-
fi when it came into being five or so years ago knows i went full circle from fast and light simple to comlicated enough to need a road map to back on a diet with only modest changes in parts selection and power supply upgrading (SE Class-A has shitty PSRR so if it is on the DC feed it is in the output of the amp
more to come as my mind drifts into new horizons of audio whackery rick style
