jc
Post by jc on Aug 22, 2015 22:32:21 GMT
I like the visual effect of LEDs on PSU boards, it's a very gratifying thumbs up when you switch on, assuming you don't get a rocket-cap between the eyes! I can also confirm Alex's statement above having done the same on both the Jaycar and the Class A.
Post by Deleted on Aug 22, 2015 23:11:32 GMT
Hello
So do you still use + / - 15v regulators or have you increased these as well ?if so what voltage regulator did you use ?
thanks for the help guys
Nick
Post by Deleted on Aug 22, 2015 23:19:04 GMT
Hi Nick Many of us use similar to what's in the GB thread at the link, or the original Silicon Chip version of this PCB with adjust resistor values amended for just over + and -20V Out before the JLH PCBs which have a couple of 100mV drop through their current limiters. Regards Alex rockgrotto.proboards.com/thread/9737/new-greg-erskine-designed-psu
pingu
Post by pingu on Aug 23, 2015 19:54:22 GMT
Very nice build Nick given me some food for thought.
Just out of interest I have emailed Audio-GD to get details of their Sun opa for a Chiara. Will post when I get a reply.
Still getting around to rebuilding or a new build of my Chiara but this may spur me on.
All the best Martin
Post by freddypipsqueek on Aug 23, 2015 21:18:02 GMT
Martin.
Same here - its the time thing. I'm interesting on any response you get from Audios GD.
Adrian.
pingu
Post by pingu on Aug 24, 2015 10:05:44 GMT
Hi Adrian,
We'll have just got a very quick reply from Audio-GD, and I quote;
"Sorry, all our OPAs have been discontinued"
So I guess that's it .......... Ah well have to stick with the Moon
Martin
jc
Post by jc on Aug 24, 2015 11:50:19 GMT
I have some original Suns (with LEDs, two I converted to normal diodes one is standard) at home doing nothing. I'll need to test them as one of them went tits up. Do you want one?
pingu
Post by pingu on Aug 24, 2015 13:31:56 GMT
Hi CJ,
Would love one to try in my Chiara , yes please Thank you for your very kind offer.
Just off to work atm but will PM you when I get home tonight
All the best Martin
Post by freddypipsqueek on Aug 24, 2015 19:34:36 GMT
Me too if you have them. I remember the Moon was a direct plug in by the Sun needed some modification - I can't remember exactly what though.
pingu
Post by pingu on Aug 24, 2015 23:09:31 GMT
I have some original Suns (with LEDs, two I converted to normal diodes one is standard) at home doing nothing. I'll need to test them as one of them went tits up. Do you want one? Hi Just having a quick break you have a PM CJ Thanks Martin
jc
Post by jc on Aug 25, 2015 13:12:19 GMT
OK, found the two working ones, I must have turfed the third duffer. I'm afraid I'm only willing to let one go so Martin has dibs, sorry Adrian. Do you want the LED version or the one converted to diodes?
Post by freddypipsqueek on Aug 25, 2015 13:19:44 GMT
No probs but I'm getting my voodoo dolly out !!!
pingu
Post by pingu on Aug 25, 2015 14:50:48 GMT
Adrian I will get my blow up doll out in that case ?
jc
Post by jc on Aug 25, 2015 18:08:30 GMT
I hope you two don't get confused with pins in the love doll and a nasty roll in the hay with the Queen of New Orleans!
jc
Post by jc on Aug 25, 2015 18:58:24 GMT
Don't forget these OPAs are rated for up to +\- 25vdc so are good candidates for higher voltage rails!
Post by Deleted on Aug 25, 2015 21:06:36 GMT
Don't forget these OPAs are rated for up to +\- 25vdc so are good candidates for higher voltage rails! As is the more modern LME49860 44V Dual High Performance, High Fidelity Audio Operational Amplifier which has superior specifications (less colouration) and will work up to + and -22V rails as well as being a direct replacement in this circuit.
pingu
Post by pingu on Aug 25, 2015 22:56:36 GMT
I hope you two don't get confused with pins in the love doll and a nasty roll in the hay with the Queen of New Orleans! Ha ha ha always up for a roll with any old queen don't you know
pingu
Post by pingu on Sept 4, 2015 12:37:47 GMT
Hi All,
Thanks to cj I now have a sun so when I have made up a new connector I will post some pix and let you know how it sounds in my very aged and original Chiara
Post by Deleted on Sept 14, 2015 19:37:00 GMT
Hello Pingu
Just sent you a pm message ..
pingu
Post by pingu on Sept 16, 2015 19:20:57 GMT
Nick I have PM'd you
Post by JamesFeline on Oct 12, 2015 21:09:40 GMT
Hello
more pics to follow soon ...
Post by steveh49 on Oct 18, 2015 11:18:36 GMT
Thought I'd ask in the Chiara thread on what appears to be THE Chiara forum: John Linsley Hood had an article in Gramophone magazine in October 1992 called "The How and Why of DIY Part 3 - A Simple Class-A Headphone Amplifier". I tracked down a copy of the article in a university library some time ago but it was just one page and had only a basic description and simplified schematic of an opamp driving a single-ended transistor buffer. You had to write to Gramophone to get the full article and schematic.
Does anyone know if the Chiara is that amplifier?
Post by Deleted on Oct 18, 2015 20:41:05 GMT
Some of the designs by JLH www.angelfire.com/sd/paulkemble/sound3.html
Post by JamesFeline on Jan 10, 2016 20:42:29 GMT
Hello
Yes that is a good web site .. use it often, happy new year to all
Post by asclepius on Jan 30, 2016 14:24:05 GMT
Hello. I'm a newcomer to this forum, having just bought a Chiara on eBay. I haven't delved inside yet, although I have read up as much as I can about it. I have a problem and wonder whether anyone can help? It is perfectly silent with nothing connected to the input, but as soon as I connect anything to either input channel or both, I get a gentle crackling on both channels equally, which is partially volume control related, but not entirely - it's there with volume at zero, and only a bit louder at full volume. Any source is exactly the same. I'm using 300 ohm Sennheiser Hd540, for what it's worth. I've tried all the 9 pin outputs from the Andante psu, they're all the same. Any ideas? Does it sound like an earthing problem? The sound is just the same as when my Quad ESL57s had a minor HT breakdown! Thanks very much. Mark
