Post by nikotime on Nov 26, 2007 21:34:27 GMT
How would I set up my rig?
It basically is (in two days when new pc arrives and I build it) Chaintech AV-710 > MUSILAND MD10 > Arcam Delta 290 > Elac CL82 and when I want to use headphones I plug them into my MD10 via the headphone amp.
So if I were to get the Green Solo, where could I put it without having to constantly unplug cables? My amps got an RCA output to a pre-amp...tbh I don't know that much about this sort of thing.
Cheers in advance
Post by mrarroyo on Nov 27, 2007 1:50:52 GMT
Post by Deleted on Nov 27, 2007 2:47:29 GMT
Miguel Is the analogue out from the Chaintech so poor, that you wouldn't even TRY it direct ino a Green Solo ? Alex
Post by nikotime on Nov 27, 2007 16:18:25 GMT
I have heard that the digital out from the Chaintech is very good which is why I purchased it. Thanks miguel, a selecter box looks perfect. Any particular one or are they all basically the same?
Post by mrarroyo on Nov 27, 2007 23:20:28 GMT
Alex, I researched a way to feed the music I have in the hard drive to an external DAC. I came across the AV-710 which many stated it has a very good optical out but not a good internal DAC or Amp.
Although I have had the AV-710 for a good while I have never even bothered to connected to my amp. Livnig in an apartment means very tight spaces, to reach the back of my computer is a major pain so I do not test its outputs since it means I have to spen an hour to take it apart and another hour to put it back together. Sorry.
Post by nikotime on Nov 29, 2007 19:11:21 GMT
Do you guys think its worth grabbing this amp for my DR150's?
Post by mrarroyo on Nov 29, 2007 21:02:06 GMT
Yes for two reasons. First the DR150 is much better than people realize, specially those who only value expensive stuff. Secondly because down the line you may wish to get a better headphone.
Post by nikotime on Nov 29, 2007 21:21:57 GMT
I'll grab it when I get some money after christmas then
