Post by Deleted on Oct 23, 2013 22:47:24 GMT
ppaproduct.blogspot.tw/ While the improvements due to some items may be debatable, reducing vibration of an Optical writer used for ripping CD/DVD s does result in improved SQ, even at the LF area. Use of shorter and more direct screened SATA cables such as the SATA 3 6GBs dual screened types is also worthwhile, especially given their modest cost. Alex P.S. I wouldn't mind a solid piece of aluminium block to bolt to my LG BR writer. Although the use of 3M 2552 aluminium anti vibration tape markedly quietens it and improves SQ, at some ripping speeds, dependent on the CD itself, it can still hum quite audibly.
