Post by simmobb2 on Sept 28, 2013 10:06:41 GMT
Hi all, I'm looking for help please in sourcing a high quality power supply for my Nuforce Icon 2 Amp/DAC. The amps rated at 18w per channel into 8 ohms and is currently supplied by a switch mode ps supplied with the amp. It's rated at 15v, 4.5amps. Does anyone have any suggestions where I could source a replacement please. Thanks.
Post by Deleted on Sept 28, 2013 14:05:29 GMT
Post by simmobb2 on Sept 28, 2013 15:24:51 GMT
Thanks but it seems there are non available in stock.
Post by Deleted on Sept 28, 2013 16:40:28 GMT
OK, I'll hold your hand Not in stock there? Copy the model number, paste into google and see what happens, pages of listings. The first in stock listing I found was MouserIf you do the same with the power requirements of the PSU you will probably find other possibilities too. ( It's what I did! ) Sometimes these "speciallity" items seem to be a daunting thing to look for but use a little logic and a search engine for your homework and you'll be near enough. Then you can check that what you have found is appropriate on forums such as this. Oh, and welcome BTW!
Post by simmobb2 on Sept 28, 2013 20:29:33 GMT
Good job someone out there knows what they're doing, thanks again.
