Post by paralaxx on May 7, 2013 7:43:39 GMT
All hello, whether somebody can take pictures of a reverse side of this amplifier that it was visible all paths and to specify the sizes which are allocated for a photo? Maybe somebody has a printed-circuit board in the *.lay format or other format?
Post by Deleted on May 7, 2013 8:30:31 GMT
parallax
Why would you want to duplicate one of these, when many report that due to the cramped layout causing heat related problems, many of these and their variants, are lucky to last more than 12 months before failing ? A major design flaw is the proximity of the electrolytic capacitors to areas of heat.
Post by paralaxx on May 7, 2013 8:47:44 GMT
sandyk Because at present I have all details for this amplifier, think the sizes of the amplifier it will be possible to increase and remove condensers from hot radiators. whether use of resistors 2W or enough 1W is expedient? small sketch of the printed-circuit board.
Post by Deleted on May 7, 2013 10:19:21 GMT
Post by paralaxx on May 7, 2013 10:25:55 GMT
sandyk
I found these photos, it is a few other scheme instead of tuning resistors there are condensers and resistors, it would be desirable to see distributing of paths of the amplifier which I gave in the first post.
Thanks.
