Post by Deleted on Jan 31, 2013 22:58:27 GMT
Could any of our resident computer wizards suggest any possibilities for the 'Settings' icon in the tray failing to work? If I tap more than the twice they suggest it even crashes Foobar! Everything else works great except this. I've tried their support and was told no-one else has reported this so they have no idea Syd
Post by Deleted on Jan 31, 2013 23:14:57 GMT
Could any of our resident computer wizards suggest any possibilities for the 'Settings' icon in the tray failing to work? If I tap more than the twice they suggest it even crashes Foobar! Everything else works great except this. I've tried their support and was told no-one else has reported this so they have no idea Syd Hi Syd that's exactly the same problem that i had with Jplay/Foobar which is why i stopped using it. works fine with Jriver so i never bothered to find out why or reporting the problem. so that's two of us. take care
Post by Deleted on Jan 31, 2013 23:26:23 GMT
Hi Shaun
I'm glad I'm not alone, at least!
Strange though it works perfectly on my music PC, which is one good thing. I only discovered this when I tried to use the JKDAC32 on my desk PC out of curiosity, which meant a trip into settings.
It still works great with my old favourite AKMods V3 DAC, still takes some beating, except for lack of anything above 96.
Syd
chris1967
Post by chris1967 on Feb 1, 2013 10:53:32 GMT
Do you have foobar shell (windows7) intergration? this might be the confict... uninstall foobar shell intergration... or foobar controls maybe the problem...
If it is not those two, i dont know...
Post by Deleted on Feb 1, 2013 23:02:32 GMT
I think it goes a bit deeper than that Chris, even after several hours attention today from someone with a fair PC knowledge, no joy. I'm disappointed that the people who made jplay couldn't at least throw out a few ideas Its setup no different on my other two machines and they are working perfectly. Its faulty even using Mini. Thanks anyway, Syd
Post by Deleted on Feb 1, 2013 23:13:28 GMT
I think it goes a bit deeper than that Chris, even after several hours attention today from someone with a fair PC knowledge, no joy. I'm disappointed that the people who made jplay couldn't at least throw out a few ideas Its setup no different on my other two machines and they are working perfectly. Its faulty even using Mini. Thanks anyway, Syd Hi Syd I'm guessing that all of your windows versions are the same on each PC. IE all 32bit or all 64bit ? take care
Post by Deleted on Feb 2, 2013 10:12:50 GMT
Hi Shaun
64 Bit on the 'faulty' PC and the laptop, 32 bit on the music PC. 5 onward caters for either as you know, I had two separate jplays for 4.
I don't have them linked, all independant.
Syd
Post by Deleted on Feb 2, 2013 10:20:54 GMT
Hi Shaun 64 Bit on the 'faulty' PC and the laptop, 32 bit on the music PC. 5 onward caters for either as you know, I had two separate jplays for 4. I don't have them linked, all independant. Syd Hi Syd could be a glitch with the 64bit playback in Jplay software. i have 32bit only which works fine with Jriver. just a thought take care
Post by Deleted on Feb 2, 2013 12:05:40 GMT
I think you're right Shaun. Although its working with the 64 bit laptop, its temperamental. The one 32 Bit m/c is fine.
Yet they say no-one else has reported issues.
Syd
Post by Deleted on Feb 2, 2013 18:13:17 GMT
Could any of our resident computer wizards suggest any possibilities for the 'Settings' icon in the tray failing to work? If I tap more than the twice they suggest it even crashes Foobar! Everything else works great except this. I've tried their support and was told no-one else has reported this so they have no idea Syd Hi Syd, Hopefully Javier will spot this post and solve your problem for you. "He`s the man" who can!! when Foobar and R/Player have operating issues. ATB. Mick.
Post by Deleted on Feb 2, 2013 22:50:14 GMT
Hi Mick Sort of hoping Javier might appear Mind you, I think Shaun's on the right track with it being related to 64 bit, though jplay folk say no-one has reported this. I'm now fairly sure its not Foobar, as mini player acts up the same way Best, Syd
Post by Deleted on Feb 3, 2013 9:42:37 GMT
Hi Mick Sort of hoping Javier might appear Mind you, I think Shaun's on the right track with it being related to 64 bit, though jplay folk say no-one has reported this. I'm now fairly sure its not Foobar, as mini player acts up the same way Best, Syd I`m using 64bit W7 Syd, both Foobar and R/Player work just fine, Javier has always set both up for optimum performance for me by taking control of my pc, and implementing any updates, etc etc. ATB. Mick.
Post by Deleted on Feb 3, 2013 10:26:55 GMT
That gives me some hope if added frustration Mick You mean using jplay also? I got the laptop running with jplay and JKDAC32 last night, lovely (forgot to check if 'settings' worked ) Switched on this morning, settings doesn't come up, neither does sound Something weird all round. Best, Syd
Post by Deleted on Feb 4, 2013 23:15:20 GMT
BIG thanks to Javier who heeded Shaun's request to send in the cavalry (thanks Shaun, saved me begging ) Javier waded in in two long sessions to sort out a mess that involved a little known piece of software (Tuneconvert) conflicting with jplay, which as far as I can tell has a few peculiarities of its own! All is very right with my musical world right now Syd
Post by Deleted on Feb 5, 2013 11:03:41 GMT
Yup, knew he would sort it out Syd, the guys a genius on all aspects of pc issues, and a great guy "to boot".
ATB
Mick
oldson
Older than a well used glove
Post by oldson on Mar 20, 2013 21:34:31 GMT
could not get jplay trial to install properly on my pc. after installer had finished, i restarted pc as per manual online. sat looking at "starting windows" screen for 20mins before giving up, resetting, running system restore and so on..... is it really worth the hassle?
jkeny
Post by jkeny on Mar 21, 2013 21:18:43 GMT
Yes, oldson, well worth the hassle although I don't know what your hassle is from - I doubt it's Jplay? The latest version, in beta testing at the moment, is a another step up in sound quality.
oldson
Post by oldson on Mar 21, 2013 21:49:36 GMT
Yes, oldson, well worth the hassle although I don't know what your hassle is from - I doubt it's Jplay? The latest version, in beta testing at the moment, is a another step up in sound quality. damn that means i will have to try again. could you not have just said "its sh.te, just buy a new dac" (?) may have been my AV software, but did try downloading and installing with it disabled. cheers
