Post by Deleted on Sept 17, 2012 6:39:55 GMT
I didn't find any reference to Async or drivers on his site And there's no response to the question in the thread. I was trying to compare the two implementations Ps I'm no 67 on the list You missed the 1st GB by only 7!! Alan the answer I posted is not in the thread, it is from a an e-mail from Domenico, the designer of the Amanero module (he is Italian). His complete answer was: -" il modulo funziona in modo isocrono asincrono. Vorrei, però, chiarire che sia il cavo USB sia il modo di trasmissione USB non influiscono sulla qualità audio dei dati in uscita. Ogni device usb ha un buffer nel quale i dati vengono accumulati e poi reclocked, quindi qualunque sia la modalità di arrivo dei dati nel buffer i dati in uscita vengono controllati soltanto dal clock degli oscillatori. L'unico vero disturbo USB valutabile concretamente è la perdita di pacchetti con conseguenti buchi nella riproduzione. Tuttavia, volendo essere pignoli si potrebbe considerare un possibile accoppiamento tra il cavo USB, con dati che viaggiano a 480Mpbs, e le piste del modulo, ma dubito che un possibile crosstalk possa essere valutabile ad orecchio nonostante la forte amplificazione dell'impianto audio."- That one should be very interesting for those who didn't make it to Will's PK DAC GB or became interested later. It can be used with a USB->I2S source like the Amanero discussed in this thread as long as the SPDIF is either removed/not installed or, if present, power is removed when using I2S to avoid signal conflicts.
Post by pagan on Sept 17, 2012 8:25:11 GMT
that could be interesting wm8804 is a very good reciever and the es9023 to me unknown but is recommended by others it depends on the layout, access to psu and clock
Post by pagan on Sept 17, 2012 9:02:00 GMT
I didn't find any reference to Async or drivers on his site And there's no response to the question in the thread. I was trying to compare the two implementations Ps I'm no 67 on the list You missed the 1st GB by only 7!! Alan the answer I posted is not in the thread, it is from a an e-mail from Domenico, the designer of the Amanero module (he is Italian). His complete answer was: -" il modulo funziona in modo isocrono asincrono. Vorrei, però, chiarire che sia il cavo USB sia il modo di trasmissione USB non influiscono sulla qualità audio dei dati in uscita. Ogni device usb ha un buffer nel quale i dati vengono accumulati e poi reclocked, quindi qualunque sia la modalità di arrivo dei dati nel buffer i dati in uscita vengono controllati soltanto dal clock degli oscillatori. L'unico vero disturbo USB valutabile concretamente è la perdita di pacchetti con conseguenti buchi nella riproduzione. Tuttavia, volendo essere pignoli si potrebbe considerare un possibile accoppiamento tra il cavo USB, con dati che viaggiano a 480Mpbs, e le piste del modulo, ma dubito che un possibile crosstalk possa essere valutabile ad orecchio nonostante la forte amplificazione dell'impianto audio."- I was trying to do a comparison between the two. both can do 44k1, 48, 88k2, 96k, 176k4, 192k all up to 24bit Just one is open, and one is closed(propriatory) as for 32bit 384k really wheres the music data files? If you,re going to use 32/384, you,ve already pre-processed your audio file, so why not just continue with out of the pc.
Post by pagan on Sept 17, 2012 9:04:32 GMT
Ps really hard to post on a tablet
His reply I'll google translate when i've worked how to on this device:)
allan
Pps Undecided between the two
Domenico's is his product, fixed for his ideas. the other is open come up with an idea, and see where it leads...
Post by Deleted on Sept 17, 2012 12:21:25 GMT
My main interest in Domenico's board is native DSD which isn't available on the Widget yet. There are some DXD (24/352.8) DLs available but it is more of a curiosity than anyhting else, besides, the files tend to be huge. Going higher than 24/192 is a little pointless IMO though I'm sure others won't agree. From what I've read the Amanero board seems to be more reliable than the Widget and its drivers are more solid and stable. Did you miss Will's ES9023 PocketKnife DAC thread?: rockgrotto.proboards.com/index.cgi?board=m&action=display&thread=6346&page=1
Post by Deleted on Sept 17, 2012 12:55:48 GMT
My Amenero board arrived this morning much quicker than I expected, given the reputation of the Italian Postal Service, so, many thanks to Domenico. Looks very good to me but much smaller than I expected . The question now is, what to do with it. Not being electronically or solder competent I reckon I'll just sit back a while and watch you guys, learning from your mistakes . Dave.
Post by Deleted on Sept 17, 2012 13:07:58 GMT
Hi Dave, just send it to me I'll give it loads of TLC ;D I'm last on the list so we can both watch from the sidelines for a bit.
Post by Will on Sept 17, 2012 14:12:14 GMT
I was surprised as well this morning when mine turned up.
As Dave says, very small (think half a PK dac), but very nicely built.
I've plugged it in and it is recognised in Foobar, which is as far as I've got.
Post by Will on Sept 17, 2012 14:13:56 GMT
I wonder if the Jean-Paul behind this pcb is the one who joined here, and then asked me for a copy of my PK Dac schematic?
Post by Deleted on Sept 17, 2012 17:59:24 GMT
I've plugged it in and it is recognised in Foobar, which is as far as I've got. Minor problem? Plugged mine in and Win7 tried and failed to load a driver for it ( so recognised it immediately ) but foobar seemed to be totally unaware of it - should this happen automatically or do you need to initiate foobar finding it? TIA, Dave
Post by Deleted on Sept 17, 2012 18:38:37 GMT
Have you DL'ed the drivers Dave? amanero.com/drivers.htmIt is a UAC2 device and under Windows it needs drivers to work.
Post by Deleted on Sept 17, 2012 19:06:05 GMT
Ah Javier, you know me too well ;D . It's always easier when you know what you're doing, isn't it? FWIW, even after DL'ing the right driver, Win7 failed to find it automatically so I had to go into Dev. Mgr. and use the 'Install Driver' facility. All done OK now and it appears in the list of Output Options - all I need now is something to go between the 'open' end of it and my amps - I await further developments . Thanks Javier , Dave.
Post by Deleted on Sept 17, 2012 20:16:40 GMT
There is a setup.exe file inside the zip, well... actually thre are two, one for 32 bit Windows (Setup32.exe) and another for 64bit ones (Setup64.exe). Running it would have been easier and quicker.
Post by Deleted on Sept 17, 2012 20:28:18 GMT
There is a setup.exe file inside the zip, well... actually thre are two, one for 32 bit Windows (Setup32.exe) and another for 64bit ones (Setup64.exe). Running it would have been easier and quicker. Oh ye of little faith!!! That was the first thing I tried but the Installation Wizard immediately came up with a message that the hardware relating to that driver either 'Could not be found' or 'Was not present', so ner!!! . Dave.
Post by Deleted on Sept 17, 2012 20:39:25 GMT
I'l check when my board arrives and report back....
Post by Deleted on Sept 17, 2012 21:18:31 GMT
I wonder if the Jean-Paul behind this pcb is the one who joined here, d then asked me for a copy of my PK Dac schematic?
Post by pagan on Sept 17, 2012 21:49:02 GMT
Dave Check in the bios that usb2 is enabled Unplug the device, load driver then plug it in
Post by Deleted on Sept 17, 2012 21:56:17 GMT
Dave Check in the bios that usb2 is enabled Unplug the device, load driver then plug it in Pagan, Thanks for your iterest. BIOS is one of the many things I try hard not to get involved with , being a numptie, but I can tell you that my MoBo is a relatively new one with USB 3.0 which works fine with a USB 3.0 exterior HDD so I suspect that may not be the problem. If I'm wrong, feel free to tell me . BTW, everything is now fine and recognised so I don't have a problem with the Amanero board.
Post by Deleted on Sept 17, 2012 22:02:09 GMT
I don't have a problem with the Amanero board. ;D ;D ;D ;D ;D ;D ;D Yes you do!!!! getting music out of it!!!!!
Post by Deleted on Sept 17, 2012 22:14:09 GMT
Javier, am I going to have trouble with you? When I refer to a problem for me I mean one that others don't have. So not being able to get music out of it still puts me well in front of you 'cos I have at least got mine while you are still awaiting yours . I will be available to advise on getting the driver installed if needed ;D ;D . Dave.
Post by Deleted on Sept 18, 2012 18:36:51 GMT
I wonder if the Jean-Paul behind this pcb is the one who joined here, and then asked me for a copy of my PK Dac schematic? I'd say they certainly look similar:
Post by Deleted on Sept 18, 2012 18:48:30 GMT
When I refer to a problem for me I mean one that others don't have. So not being able to get music out of it still puts me well in front of you 'cos I have at least got mine while you are still awaiting yours . I may not have the board yet with me but I do have a DAC ready to make it sing! I've just checked the tracking # against Correos' web (Spanish Mail) and my Amanero should be here any time now. Any of the lucky ones who have received their boards has already tried it? if so, what are the 1st impressions.
Post by Deleted on Sept 18, 2012 19:13:13 GMT
Ooh er, I've only got "left international office of origin". Are you doing better than that? ( green jealous smily thingy if there was one )
Post by Deleted on Sept 18, 2012 19:21:58 GMT
Ooh er, I've only got "left international office of origin". Are you doing better than that? ( green jealous smily thingy if there was one ) Nope, got the same as you but it usually takes 5 days since it leaves origin and delivery. So far it has been almost the same for things sent from the UK, the Neverlands or any other EU country. I guess they'll be with us before Friday. Do you have you PK ready?
Post by Deleted on Sept 18, 2012 19:31:15 GMT
[I may not have the board yet with me but I do have a DAC ready to make it sing! Have I missed something? - it did happen once in 1978, I think it was ;D - what DAC is that then? Dave.
