Post by southpaw on Jul 27, 2011 21:16:49 GMT
Bought this a little while back It has brought some real warmth and fun back to my system. It comes with some cheapo Chinese valves that I should get round to changing but it sounds so nice
Post by mrarroyo on Jul 28, 2011 10:54:09 GMT
A set of NOS or Russian valves would be a nice addition.
Post by southpaw on Jul 29, 2011 14:28:40 GMT
Bidding for a pair of cv1888 that should improve matters
Post by southpaw on Aug 21, 2011 23:06:07 GMT
Post by southpaw on Sept 2, 2011 23:31:36 GMT
NOS 1970s russains turned up today Only £10 so keeping it well within team cheap git territory ;D Its been a while since I've changed a valve, am I right in thinking they just lift out and plug back in? IE you don't have to match numbered pins up?
Post by mrarroyo on Sept 3, 2011 12:39:35 GMT
The bottom of the tube has to be aligned with the socket. You will see the pin arrangement plus there is a "key" on the tube base that aligns with the socket. On the enclosed pic you will see at about 3:00 o'clock a "hole" in the center hole, the "key" in the tube base aligns with it.
Post by southpaw on Sept 3, 2011 23:01:58 GMT
ah that's it - its all come back now thanks for the reminder. Should get them running tomorrow.
Post by ozelui on Apr 3, 2012 7:51:16 GMT
Hi there!
Have you tried any mods to the Yaqin? I have read about improvements when changing caps & internal wiring. How is it sounding with the new set of tubes by the way? I am considering buying one for an FM tuner...but there is also an Indeed MKIII tube buffer as well. Anyone out there with info/experience about?
