New Hybrid Class A / Tube amp kit coming soon!
May 30, 2011 5:00:13 GMT
Post by Garage1217 on May 30, 2011 5:00:13 GMT
Hey guys, With the blessing of Mike, I wanted to post up a DIY kit that Frans and I have been working on. I really liked the idea of an affordable hybrid tube amp like the Bravo, Muse and indeed varieties but felt they could all be a LOT better than they are and really perform! So in short (the only short part of this post), I got with Frans and after beating up designs, modifications and new additions day and night (literally day and night as I am in the US) We have come up with Project Sunrise. And to all due Credit, Frans put one heck of a lot into this design! It could not have been done in without him so a big thanks to Frans!
Since I cannot post detailed photos of the production kit yet (pre-production, prototypes are shipping out to various people late next week) I thought I would give some info and open up a q/a session about what the amp has to offer...
Board Overview
- 2 layer, black masked circuit board with gold wash / full lower and upper ground planes! So much was added in the design, the board had to grow to 4" x 5"
- Both 6V and 12V selectable heater voltage to easily roll 12au7 / 6922 or similar tubes via a jumper
- Dedicated heater power supply circuit
- Turn on / off protection so you can safely leave your cans plugged in while turning on and off the amp!
- All amplifier components are US sourced from reputable retailers! NO FAKE / COUNTERFEIT ELECTRICAL COMPONENTS PERIOD! All top quality parts
- User configurable LED color
- Multiple jumper options to help dial in the amp the way you want it. More info below on the jumper options.
Input capacitor options
- Input cap bypass via jumpers as the best sounding cap is no cap. Running no cap can cause a scratchy sound from DC when adjusting the volume, but once volume / gain is set, there is no need to adjust it really which is why bypass jumpers are provided.
- For tuners, you can run 2 / 2.5 / 3.5 or 5mm lead spaced input capacitors up to 8mm diameter / multi drilled pcb. Reference input caps that will ship are Nichicon Muse ES
Output capacitor options
- PCB drilled for 5 / 7.5 and 10mm leaded caps. Reference output caps are Nichicon KZ series / FG will be available later per request Up to 18mm diameter caps accepted!
Power supply capacitors
- PCB drilled for 5 / 7.5 and 10mm leaded caps up to 18mm diameter. Reference power supply caps are Nichicon FG / KZ available upon request
Resistors
- All signal resistors are Vishay 1%
- Variable 25 turn 1/2w bourns trimmers for precision bias adjustment - Output resistor values are selectable via jumpers between 10ohm and 68ohm. You can of course change the values to whatever you like if you feel like doing something different than the reference design
Other features...
- Onboard rugged power switch with easy access / alternate vias to mount a remote chassis on-off switch
- Onboard 2mm barrel plug jack with easy access alternate vias to solder in 24V input wires from a chassis plug
- Onboard RCA input jacks with easy access alternate vias to solder chassis mount RCA leads
- Neutrik 1/4 inch / 6.3mm phono output
- Bourns pro audio volume pot with nice black / silver machined aluminum knob. Great feel IMO over the ALPS miniature version.
Chassis
- Partially naked / open air design, laser cut acrylic chassis will be available which is similar to the common open air designs found on the overseas kits, however the ones I will offer have cutouts for input and output caps as well as provisions to help vent the heatsinks.
Power Supply
The power supplies I have to offer are standard 2A / 24V switch mode power supplies, almost identical to the ones that ship with the Indeed series amps. They are a cheap alternative to building a DIY supply and work great. The input jack on the kit takes a 2.1mm center pin barrel connector so if you already have a bravo or similar with 2.1mm barrel connector, then you can re-use your own supply!
Kit options
You can buy a kit in various trim levels as well as have us build your amp, ready to run out of the box! All amps built by us carry a 2 year warranty on the amp itself / 1 year on the power supply and 60 day on the tube.
All kits will come with a detailed instruction manual with photos so that even a novice solder slinger can get up and running in no time!
Kits are as follows...
store.garage1217.com/project-sunrise-hybrid-class-a--tube-headphone-amplifier.html
Power supplies, tubes and chassis options are sold separate. Check out my website for more details! store.garage1217.com/diyhisuki.html
Feel free to ask any questions you would like! Pre-orders are being accepted now and are welcomed! The ship date of production units will be June 30th 2011. On G1217 built serialized units, you can reserve the serial number you want! 2-50 are available right now. Serial numbers will be laser etched onto the top part of the chassis.
Who the heck are you?
My name is Jeremy Helms. My small company G1217 is based in Arizona under the scalding desert sun. I have been supporting the DIY automotive LED industry for many, many years so no, we are not a new startup! I have a passion for hifi and more specifically headphones and want to extend my business into the DIY parts and kit world as I have a passion for it. I pride myself in fast shipping, quality parts and fast email responses "I do my best to respond fast for my overseas customers since we are on different schedules" If you have any questions at all, hit me up anytime!
Board Overview
Resistors
Other features...
Chassis
Power Supply
Kit options
) so it will be good fun testing an assortment in the SunRise amp
, me having a modded Bravo 12AU7 and quite a large stash of various NOS tubes. Too late now but one thing if a Rev 2 board should ever be considered is mounting points for a 1/8" socket either as well as or as an alternative to the 1/4" socket. Not a big fan of adapters if they can be avoided.
