Post by PinkFloyd on Mar 16, 2010 9:01:59 GMT
not creaming my pants yet ;D
Post by Deleted on Mar 16, 2010 14:00:24 GMT
Ok had my G2 running for a couple of hrs with supplied E. Harmonix 6922 and PSU on loop before listening test. First impression is, very nice, not creaming my pants yet, as the Bravo and Miritiy are a tough act to follow. Mick. Probably very similar sound once it's had a chance to get going? My Miridy was a bit underwhelming at first and it seems to have become beefier with time. I really like it actually; especially with less noise than the Bravo as well. Mick, does your Miridy take almost a minute to get going from cold? Mine takes a long time to make any sound. The Bravo was much quicker to come on. (ie the Valve has warmed up) Ian
Post by clausdk on Mar 16, 2010 19:15:12 GMT
Can the blue diode be exchanged by something not so bright ? Prefer no light at all, only the tube should be on
Post by Deleted on Mar 16, 2010 19:19:59 GMT
Just short the blue LED, it has NO function other then 'cosmetic'. The red LED has a function and should be left alone (is part of the CCS in the anode circuit) Solderdude
Post by Deleted on Mar 16, 2010 19:20:37 GMT
Can the blue diode be exchanged by something not so bright ? Prefer no light at all, only the tube should be on I seem to remember Frans saying that the light was part of the workings in some way. However, he's going to extinguish mine for me while modding my Bravo. EDIT - Aah - we crossed posts!! Ian
Post by Deleted on Mar 16, 2010 19:56:47 GMT
Yes Ian they both do, builds up slowly in one channel, then the other, over the course of perhaps 10-15 sec before its game on. The PSU came today, its a very nice quality item, a bit different from the advertised spec on the website, this now has no internal fan, not needed in my opinion, as it hardly gets warm, after powering my Miritiy all day. Iam getting all Amped out at the moment, so will let you know if there has been any improvement on SQ when i can make a positive decision one way or the other.
Post by Deleted on Mar 16, 2010 20:16:41 GMT
Mick, the link in your other post re: adapters doesn't connect and I can't find the original post that Mike put up. I'm going to try putting something a bit beefier onto mine just in case I can get it to reach a bit lower and supply a bit more attack. I didn't realise that the connectors were different in the G2. If it was a bit cheaper and without the $20 postage I'd get one to do a comparison. It comes to somewhere around $130 now so it's creeping into new territory as far as cost goes. However, it may be to do with quality of components and therefore the build quality of the amp as well from the sounds of it. I must admit, I am really happy with the Miridy taking it's daft cost into account. It has perhaps a little less bass than the Bravo, (A fraction less depth) but some people may like that in any case. It looks almost like a carbon copy in any case. I've been spoilt with the V2 which is positively subterranean. Ian
Post by Deleted on Mar 16, 2010 20:41:32 GMT
Ian, page 32 Bravo indeed Amp reply 468, that works, don`t know why mine doesn`t, i copied and pasted it Its a 5Amp PSU so there is loads of power, considering the standard G2 unit has 1.8 Amps, it cost £46 including postage, not cheap but certainly looks a quality item. Mick.
Post by PinkFloyd on Mar 16, 2010 20:49:45 GMT
Guys, if you go to ebay and search for "120w 24v power supply" you will see a selection of 15 - 24V (6 amp) power supplies.... these are PERFECT for use with the Bravo / Indeed amps and also have interchangeable tips. I only realised today that the indeed G2 requires a 2.5mm plug whereas the Bravo and indeed G1 require a 2.1mm type..... the beauty of these "laptop" type power supplies is that they come with a selection of interchangeable tips so will fit pretty much anything..... you can also set the voltage between 15 - 24V so this PSU could also be used with the Aune (or similar types of amp) that require a 20V input. This one "looks" good and is certainly more trendy than the plain old black boxes. I have just bought one and will let you know how it performs.... will try it with the NG27 / the Aune / the G2 / the G1 and the Bravo...... Mick.... if the Rapid one doesn't have the fan in it then tell them it's not the one you want.... they are pretty good and will either ask you to return it for a refund or will tell you to keep it and refund you Mike.
Post by PinkFloyd on Mar 16, 2010 22:15:41 GMT
OK..... the Sample G2 will ship to Leo tomorrow morning and then it heads up to Glasgow to Attilio..... Only two so far so, if you want a try out of the G2 please add your name to the list..... I would ask that each person in the tryout keeps the amp for a week and then sends it to the next member on the list (royal mail 1st class recorded / about £3.30)..... don't worry about "fingerprints" or any unintentional cosmetic damage but please make sure the amp has a wrapping of bubblewrap before sending to the next member..... I don't need to say this, you're all sensible Leo, I forgot to stick some domed feet onto the base of the amp.... do you have some? If not I'll send some to Attilio and he can stick them on (I have hundreds)..... god only knows why "indeed" don't fit little stick on feet..... that's one aspect of the amp that will really piss people off..... Oh sod it, it's only 10pm, I'll go out to the workshop now and stick some feet on..... means opening the package up again..... oh well, in for a penny in for a pound ;D Mike.
Post by Deleted on Mar 16, 2010 22:20:19 GMT
Mike,
I would love to hear the G2 although it'll probably get me buying one afterwards!!!
Would it also be safer to take the valve out and pack it rather than leave it sticking up?
Thanks for giving us the chance to hear it. Much appreciated.
Post by PinkFloyd on Mar 16, 2010 22:34:20 GMT
OK.... last minute stuff!...... package opened and 4 x rubber domed feet added I would have preferred to fit clear (see through) feet but don't keep them in stock so these will have to do for the sample G2...... IMO they should all be fitted with rubber feet and I will make my opinions known to Peter when he returns from China (to Hong Kong)..... no reason, AT ALL, why these amps should come without feet..... Anyways...... the sample model will now ship "with" feet Mike.
Post by PinkFloyd on Mar 16, 2010 22:39:32 GMT
Mike, I would love to hear the G2 although it'll probably get me buying one afterwards!!! Would it also be safer to take the valve out and pack it rather than leave it sticking up? Thanks for giving us the chance to hear it. Much appreciated. Ian OK Ian, You're third on the list. I have packed the 6922 valve in a carton and it's a simple case of slotting it into position before listening to the amp ;D Do you really think I would ship the G2 with the valve in position? I have also included the "instruction sheet"...... All good to go..... I'll let you know as soon as Attilio has finished evaluating the G2 and he will send to you. Mike.
insomniac
Team Zopiclone
Post by insomniac on Mar 16, 2010 22:50:38 GMT
Totally agree with Mike about the need for rubber feet as the amp tends to skeet around a bit without them, especially when positioned on a smooth surface when plugging/unplugging the headphones. Still burning in the G2 here slowly but surely (attended burn-in only ) it's sounding very nice already and matches well with my HD650's with plenty of power to drive them. I've noticed the occasional mobile phone signal but that doesn't bother me too much.
Post by PinkFloyd on Mar 16, 2010 22:56:48 GMT
Totally agree with Mike about the need for rubber feet as the amp tends to skeet around a bit without them, especially when positioned on a smooth surface when plugging/unplugging the headphones. Still burning in the G2 here slowly but surely (attended burn-in only ) it's sounding very nice already and matches well with my HD650's with plenty of power to drive them. I've noticed the occasional mobile phone signal but that doesn't bother me too much. Dave, I didn't know you were in the market for a new amp..... so whaddayouthinkofitsofar? Mike.
Post by Deleted on Mar 16, 2010 23:07:14 GMT
I have clear silicon rubber ones on my Amps 11mm dia x 5mm high on mine perfect, have 2 sets left over, first 2 PM`S I GET CAN HAVE THEM.
Post by Deleted on Mar 16, 2010 23:10:47 GMT
Post by PinkFloyd on Mar 16, 2010 23:22:21 GMT
;D
insomniac
Team Zopiclone
Post by insomniac on Mar 16, 2010 23:34:16 GMT
Totally agree with Mike about the need for rubber feet as the amp tends to skeet around a bit without them, especially when positioned on a smooth surface when plugging/unplugging the headphones. Still burning in the G2 here slowly but surely (attended burn-in only ) it's sounding very nice already and matches well with my HD650's with plenty of power to drive them. I've noticed the occasional mobile phone signal but that doesn't bother me too much. Dave, I didn't know you were in the market for a new amp..... so whaddayouthinkofitsofar? Mike. Mike, I liked the appearance of the G2 and based on the positive reports of the original Indeed amp, decided to have a dabble As many on here know I'm mainly a "solid state" kind of guy but remain open to other options, in this case the G2. The first thing that hit me upon first listen was the Bass... very satisfying and deep Bass but not over the top. The midrange is punchy and the highs slightly rolled-off. The amps sound is coloured but musical and enjoyable all the same with the various songs/music styles I have listened to. (a bit of everything) The amp has only been running for around 20-30hrs total but already sounding very promising so for the money involved I'm well pleased with it. What it lacks in numbers: SNR etc it makes up for in charm IMO. Am I going to do away with my SS amp in favour of the G2?.... no but it makes a nice alternative for when the ears crave something a little different Dave
Post by Deleted on Mar 17, 2010 7:32:46 GMT
Do you really think I would ship the G2 with the valve in position? No Mike. Not you. You never know, that Attilio might do it and blame me!!!! Ian
Post by attilio on Mar 17, 2010 10:13:46 GMT
hey, just because my name sounds like Attila the Hun. doesn't make me a vandal. attilio
Post by Deleted on Mar 17, 2010 10:37:21 GMT
hey, just because my name sounds like Attila the Hun. doesn't make me a vandal. attilio I just don't want to get a detention. Ian
Post by covenant on Mar 18, 2010 17:13:15 GMT
I have won one of these on fleabay for $61 plus p&p, is that a good price? I have noticed that you can get them with different tubes. Mine is fitted with an Electro-harmonics 6922 EH but there is a more expensive Peking 6N11. I always fancied having a go at tube rolling so getting the cheaper one is fine for now. Looking forward to it arriving.
Post by leo on Mar 18, 2010 19:40:09 GMT
The G2 arrived today (thanks Mike) its a sweet looking little thing in the flesh isn't it After an hours warm up initial impressions , it goes plenty loud enough for these sensitive ears using HD250 linear II,I have the pot set at just under nine o'clock position. I've only used one source so far (Beresford Caiman) , going through a few random music tracks the sound is very pleasant , theres a warm bloom to the upper bass/mids. (valve rolling probably alter the signature quite noticeably ) certainly no sharp or edginess so far. I'd say this amp would go nicely with a source which is on the slightly thin and flat side as it would probably fill things out making for a more interesting listen. There does seem to be some high frequency roll off , maybe due to the Mosfets being high capacitance ? But to most I doubt this would be a problem , actually be a benefit for a hard edged source, its got quite a bit of kick too. I'll try the modded Buffalo23s later and at the weekend hopefully have a probe around
Post by leo on Mar 18, 2010 19:44:46 GMT
BTW, without the rubber feet it would be sliding about all over so thanks for adding those before sending it
