Post by krisno on Nov 9, 2009 16:59:48 GMT
I think i will solve the DAC the easiest way ... get the Asus Xonar Essence ST soundcard... will use the amp on this, and will use the V2 if it sounds nice. It is a little bit less cable clutter than the Pico $300 USB only dac. Though the Pico is a nice build. With som RCA couplers you might be able to attach it directly to the back of the x-can.. that would be sexy hehe
Post by PinkFloyd on Nov 9, 2009 22:50:41 GMT
Pink.... is the V1 less edgy (i presume so) and harsh and bright than the V2? Kris.... I STILL don't find the V2 "bright" (never have done) and am CONVINCED it's something in your chain of components that's causing this.... either that or I am as deaf as a post!!
Post by krisno on Nov 10, 2009 11:30:09 GMT
Its the source thats problem... yes... but I will stick to that V2 is brighter than my analog out by a far way - without the mod.
Have you guys seen the new techtubes ? lets hope they make a 6922 edition some day. They get good reviews, extremlt transparant , smooth, .... though some comment that this new type of tube dont have the magic of the nos tubes. I don't know, but you should check it out.
K
Post by Deleted on Nov 10, 2009 11:41:20 GMT
Its the source thats problem... yes... but I will stick to that V2 is brighter than my analog out by a far way - without the mod. Have you guys seen the new techtubes ? lets hope they make a 6922 edition some day. They get good reviews, extremlt transparant , smooth, .... though some comment that this new type of tube dont have the magic of the nos tubes. I don't know, but you should check it out. K Krisno If you are referring to the tubes made at the old Mullard site at Blackburn in the U.K. , they went bust months ago. SandyK
Post by krisno on Nov 10, 2009 13:25:52 GMT
oh no.... sandyk... is that true? Yes I was referring to them. My god - er they bust?? It would be so nice with a real tube replacement. christ... are you sure? the first tube was just released.
Post by Deleted on Nov 10, 2009 19:43:41 GMT
Krisno I haven't seen anything further, but the parent company went into receivership. SandyK
Post by PinkFloyd on Nov 10, 2009 21:46:51 GMT
Its the source thats problem... yes... but I will stick to that V2 is brighter than my analog out by a far way - without the mod. Have you guys seen the new techtubes ? lets hope they make a 6922 edition some day. They get good reviews, extremlt transparant , smooth, .... though some comment that this new type of tube dont have the magic of the nos tubes. I don't know, but you should check it out. K If you want to go SMOOTHER I totally recommend you try an X-10D inline between your source / amp.... they iron out a lot of rough spots
Post by krisno on Nov 11, 2009 17:19:25 GMT
hehe... are you insaine my friend. I dont need more tubes. The AKG K 701s are the problem. No matter what you do, it reveals any flaw, they are not really magical. But we will see.
Post by krisno on Nov 12, 2009 23:55:55 GMT
Mike .... do you have those nice metal knobs for the x-can v2? I really think it looks way better than that plastic....
Post by Deleted on Nov 13, 2009 2:33:58 GMT
Metal knobs can induce noise while touching it. Mike and others will be able to explain why isolating type knobs are better. Miguel With a properly designed amplifier this should not happen. You may have noticed in the Jaycar HA, that there is an earthing lead at the front of the attenuator. There is also one in the Class A HA. Even if not fitted with a 3 pin mains plug, taking a lead from there to the the 0volts/earth line should stop this problem. Alex
layums
Thank you for the untips
Post by layums on Aug 9, 2012 21:17:51 GMT
I got my v2 feeding off a hrt musicstreamer ii+ it's a good match. Highly recommend it.although my v2 is mike modded with the pana caps kit.
layums
Post by layums on Aug 9, 2012 21:19:31 GMT
Its the source thats problem... yes... but I will stick to that V2 is brighter than my analog out by a far way - without the mod. Have you guys seen the new techtubes ? lets hope they make a 6922 edition some day. They get good reviews, extremlt transparant , smooth, .... though some comment that this new type of tube dont have the magic of the nos tubes. I don't know, but you should check it out. K If you want to go SMOOTHER I totally recommend you try an X-10D inline between your source / amp.... they iron out a lot of rough spots What's the differences between x-10d and x10v3. Tube rolling?
Post by mrarroyo on Aug 10, 2012 9:50:08 GMT
If you look up Mike's thread here on upgrading MF gear you will see these are two different beasts. Personally after owning both I prefer the X-10D.
layums
Post by layums on Aug 19, 2012 7:14:58 GMT
Thanks for the input. Might try and track one down with a 1st xcan also and do the mikeymods.
