Post by rickcr42 on Jul 17, 2008 15:20:08 GMT
Post by PinkFloyd on Jul 17, 2008 23:19:05 GMT
Thanks.... appreciated Rick.
Post by fanboi on Jul 19, 2008 14:07:34 GMT
Good info, tks your rickness. Just to add a little, I recently had to replace some Chinese 6N1s used as drivers in a PP amp and found some conflicting info WRT replacements - eventually found specs indicating them to be virtually the same as the Russian 6N1P, 6N1P-EV being the premium version so I replaced them with a matched, cryo'ed pair of 6N1P-EV with no problems and an improvement in SQ. I gathered these to be fairly common in Chinese amps (the 6N1) so thought it worth sharing. The same amp used 6N2 as preamp tubes, these I replaced with Groove Tubes 12AX7M (Mullard reissue) after rewiring the sockets for 12v heater supply - another worthwhile change.
