Post by dejanm on Sept 18, 2008 8:06:43 GMT
I understand now. Thanks ...
Post by dejanm on Sept 18, 2008 16:11:16 GMT
In the X-CAN V2 there are two transistors of the type: C3788. Does anybody know where these trans can be bought ? Replacement ?
Post by Deleted on Dec 13, 2008 0:09:03 GMT
I was having a dig through my musical parts bin today and found a Vol.knob for the xcan which I reckon is just right! (think it's a tone control off a Marshall)
Post by krisno on Dec 16, 2008 17:47:52 GMT
PinkFloyd sells both a 'Elna' value kit and the Panasonic kit for the X-can V2.
Which of these should I choose? The Elna is alot cheaper, and as far as I have understood, the Elna and Panasonic kit is exactly the same except that the caps are Elna brand in the first one?? Can anyone confirm this?
I want a sharp sounding amp, with the most details, the Elna is said by PF to be warmer, but does that mean lack of details / muddy? compared to using he Panasonic kit?
Anyone can tell me a little about the sound differences before I order?
Is there really any major difference??
thanks!
Kris
Post by Deleted on Dec 17, 2008 2:51:43 GMT
Miguel Back in my training school days with the then Postmaster General's Department,(1955?) we were taught that an amplifier's bandwidth should be at least 3 to 5 times the maximum frequency to be reproduced. Oh, and that was before transistors came into general use. (We also built valve amplifiers as class projects !) Graham would disagree with you about not needing wider bandwidth to correctly reproduce the higher harmonic structure ? A good amplifier should not have an artificial warmth about it either. A well designed SS amplifier should have >20dB better signal to noise ratio than a typical valve amplifier, hence Leo's comments about noisy valves in another thread. Incidentally, what's the point of having 24bit 96KHZ audio with BluRay discs, and having valve output stages, if an average valve amplifier doesn't have 3 to 5 times that bandwidth ? i.e. 288KHZ minimum. Obviously, a normal valve amplifier is NOT suited to these requirements, although the new TechTube Valves (due in December?) from the old Mullard factory at Blackburn in the U.K. should be considerably better, due to their reduced internal capacitances, as well as their +-10% tolerance, compared to the industry standard of +-20%. Alex www.techtubevalves.com/
Post by XTRProf on Dec 18, 2008 8:31:43 GMT
Hi Alex,
Isn't the extended frequency meant to avoid the brickwall filter that can cause phase problem than actually being able to hear them. So hearing thru a tube amp after all the 24bit 96Khz conversion to analogue will not be disastrous, although when the analogue bandwidth is not large enough, the high frequency analogue square waves can be clipped due to poor harmonic structures higher up the range.
Anyway, this is what upsampling is all about and that is not to cause phase problems that could be heard or measured. I take it the hirez system to have this advantage as well on top of the added resolution at 24 bits.
Post by Deleted on Dec 18, 2008 8:51:24 GMT
XTRProf Remember that this was stated long before brickwall filters were even thought about. It would have more to do with the preservation of the harmonic structure. Modern thinking would seem to make this 3 to 5 times requirement quite conservative. Don't forget that even Sony was selling tweeters to go with SACD that extended past 70KHZ. There are other tweeters available that go past 100KHZ. Alex
Post by Deleted on Dec 18, 2008 20:21:23 GMT
Miguel That was stated for general information.I wasn't disagreeing with your statement. However, high resolution source material requires similar consideration if it is to sound any better than just a well recorded CD. Alex
Post by Deleted on Dec 20, 2008 23:23:06 GMT
In the X-CAN V2 there are two transistors of the type: C3788. Does anybody know where these trans can be bought ? Replacement ? Did anyone ever answer this one? If you mean 2SC3788, try www.dalbani.co.uk/search.phpthis takes you to the main search, then tap in the code.
Post by hooograa on Jan 22, 2009 13:56:20 GMT
I had to replace those and couldn't find them but I found a substitute of nte2501. I have two V2's one with 2sc3788 and one with nte2501 I can't tell the difference. David
jc
Post by jc on Jan 19, 2015 16:20:08 GMT
Seeing as everyone else has done it, I thought I'd have a go.... ...at putting a silly volume knob on!
Post by PinkFloyd on Jan 19, 2015 20:41:15 GMT
Seeing as everyone else has done it, I thought I'd have a go.... ...at putting a silly volume knob on! Nice knob Chris but will it clear the LED when you crank her up?
Chris53
Post by Chris53 on Jan 19, 2015 21:03:29 GMT
The bacon slicer volume control!
jc
Post by jc on Jan 19, 2015 22:05:22 GMT
The bacon slicer volume control! ...or a segment of cheese! ( That makes it a cheesy, erm, no, not going there ) How loud does it go, oooh I thinks it goes up to cheddar my larrd. By eck lad, yer soft sootheners no now't, mine goes all way upt' Wensleydale!Yes Mike, it does clear the LED. It's ship-shape and Bristol fasion, plain sailing all the way to pierced eardrums!
Post by PinkFloyd on Jan 19, 2015 22:17:55 GMT
The bacon slicer volume control! ...or a segment of cheese! ( That makes it a cheesy, erm, no, not going there ) How loud does it go, oooh I thinks it goes up to cheddar my larrd. By eck lad, yer soft sootheners no now't, mine goes all way upt' Wensleydale!Yes Mike, it does clear the LED. It's ship-shape and Bristol fasion, plain sailing all the way to pierced eardrums! Plain sailing until it hits the "headphone jack rock" then it's a matter of "all hands on deck" chanting "why can't it go louder, why can't it go louder (Cap'n) with a ho diddle diddley and a main brace a fiddley".......... I'll throw myself overboard
jc
Post by jc on Jan 19, 2015 22:26:05 GMT
Not before you're keelhauled for your mutinous insubordination my lad. The only Bounty around here is the chocolate bar and you ain't getting that either!
Post by PinkFloyd on Jan 19, 2015 23:01:10 GMT
Not before you're keelhauled for your mutinous insubordination my lad. The only Bounty around here is the chocolate bar and you ain't getting that either! Splice the main brace you dog! Let the brass monkeys roll! For this day we will be merry and will feast on the cargo of chocolate! Nuuuuts, whole hazelnuts.... Cabdbury take 'em and they cover them in chocolate! Ooooh arrr, that be right decent charcolate carpn!
Post by PinkFloyd on Jan 19, 2015 23:02:54 GMT
I'm actually starting to get concerned about myself
ronzo56
Post by ronzo56 on Jan 25, 2015 22:44:21 GMT
Not before you're keelhauled for your mutinous insubordination my lad. The only Bounty around here is the chocolate bar and you ain't getting that either! Splice the main brace you dog! Let the brass monkeys roll! For this day we will be merry and will feast on the cargo of chocolate! Nuuuuts, whole hazelnuts.... Cabdbury take 'em and they cover them in chocolate! Ooooh arrr, that be right decent charcolate carpn! Enjoy your Cadbury chocolates and other candy bars. We won't be over here much longer. Hershey's has forced Cadbury in the U.K. to stop selling its products in the U.S. So we are stuck with the high sugar, lower fat, soy emulsified crap they call chocolate. I hear they are a horrible employer as well. Allegedly that is. And the opinion on the taste is wholly my own and no one else's, and is not the opinion of Rock Grotto, or any of its members. There I have my arse covered. I mean if there are willing to take away someone's favorite chocolates what else are they capable of!!!
jc
Post by jc on Jan 29, 2015 23:21:30 GMT
No worries, it's not real Cadbury anymore. Kraft bought them amd are starting to dumb down the chocolate recipes to their own level of total crap
