Post by audioray on Dec 14, 2005 13:10:12 GMT
hello one more time i replaced the ten large caps on the X-10 board with fc-35v-1800uf. the two smaller caps are 50v-10uf. polarized. my question is. should i replace these caps with NP types. wich value. same as V-2 ? thank you
Post by PinkFloyd on Dec 24, 2005 15:03:01 GMT
hello one more time i replaced the ten large caps on the X-10 board with fc-35v-1800uf. the two smaller caps are 50v-10uf. polarized. my question is. should i replace these caps with NP types. wich value. same as V-2 ? thank you Yep, the 2 x 10uF are input caps and can safely be removed and jumpered over or you can fit 10uF non polars in their place... same goes with the V2, if your source doesn't have any DC at its output (most modern ones don't) then you can safely remove the 10uF input caps and just jumper over the pads with a zero ohm link.
