Post by videoguy on Apr 19, 2018 0:50:28 GMT
Hi: For any that are building the AKHA headphone amplifier, there is another part that has been discontinued. Checked Mouser & they only had 2ea. of the SF 14 Diode that is used on the AKHA amplifier card & 4ea. are used in each power supply. I was able to get 100 of them on ebay, at the right price.
If you have the pcb's & dual transistors better get busy w your build as thru hole parts are starting to disappear.
You have had fair warning!
pingu
Post by pingu on Apr 22, 2018 10:35:46 GMT
Hi: For any that are building the AKHA headphone amplifier, there is another part that has been discontinued. Checked Mouser & they only had 2ea. of the SF 14 Diode that is used on the AKHA amplifier card & 4ea. are used in each power supply. I was able to get 100 of them on ebay, at the right price. If you have the pcb's & dual transistors better get busy w your build as thru hole parts are starting to disappear. You have had fair warning! Hi Videoguy, The AKHA is still on the bench (together with the Marsh HA) I’m afraid, but I have all the bits. Thanks for the info as I said I have a few sf14s but I checked out suppliers and all at silly prices. However Radio Spares have sf16s at a very reasonable price. Basically same diode but a bit larger piv. So if anyone is stuck they’ll do I’m thinking. All the best Martin
pingu
Post by pingu on Apr 23, 2018 11:17:17 GMT
Post by videoguy on Oct 28, 2018 21:44:56 GMT
Hi Martin: Check your messages.
