jc
Post by jc on Jun 14, 2015 15:51:09 GMT
I was hoping to get the order in for these before trotting off to the UK for a week which is this coming Wednesday. So far I have; Myself x8 boards SandyK x8 boards radius x2 boards BUT you actually need 4, OK with that? Any other takers? Especially those new to these type of builds that don't have any JLHs from previous group buys. Not forgetting, of course, they have great results in the power supplies feeding all sorts of kit. I know of at least one more upcoming project that require these as well . Obviously 20 boards won't help the price much so get in while you can, fill yer boots, grab a stash, stock pile 'em, create a JLH mountain, who knows when there'll be another group buy for these! RSVP...
jc
Post by jc on Jul 3, 2015 22:50:51 GMT
No more takers for this? I'll leave it another week for any late comers. youuuuuu waaaaaaaant soooooooome
Post by Deleted on Jul 3, 2015 23:04:38 GMT
No more takers for this? I'll leave it another week for any late comers. youuuuuu waaaaaaaant soooooooome Hi Chris Have you had a chance to see if this PCB design can also be modified as a VReg + JLH for powering SSDs etc. ?
Regards Alex
P.S. Bill still needs a few mailing addresses for the main PCBs and the LS313 and LS352 dual transistors.
jc
Post by jc on Jul 3, 2015 23:14:20 GMT
It didn't even cross my mind to be honest!
Post by Deleted on Jul 4, 2015 10:35:46 GMT
VReg +JLH PCB for SSD etc.
For +5V you can use 110/330, 120/360,130/390 ohms. A heatsink will need to be used/made that doesn't foul the input terminal block. The additional 100nF and 10uF would be mounted underneath the PCB
jc
Post by jc on Jul 4, 2015 13:04:11 GMT
Hi Alex,
Is there any value for "L"?
Although a little inconvenient for installation you could possibly use a normal heatsink on the LM317 if the connector block was on the underside with taller PCB spacers? Other than that a slight stretching of the design would need to be drawn up if you wished to accommodate the changes into the design.
Post by Deleted on Jul 4, 2015 22:20:51 GMT
Hi Alex, Is there any value for "L"? Although a little inconvenient for installation you could possibly use a normal heatsink on the LM317 if the connector block was on the underside with taller PCB spacers? Other than that a slight stretching of the design would need to be drawn up if you wished to accommodate the changes into the design. Hi Chris "L" is for Link. You could probably use a piece of aluminium for a heatsink. In the case of a SSD, the heatsink wouldn't need to be too big, as the LM317T is rated for >1.5A, and SSD current draw is fairly low (<.5A) and not continuous. Regards Alex
Post by Deleted on Jul 5, 2015 4:14:22 GMT
Hi Chris You will be able to use a small heatsink like those used in the SC DAC and Preamp PSUs, simply by turning it around so that it sits higher.
Regards Alex
jc
Post by jc on Jul 5, 2015 21:49:55 GMT
Oh, too simple! I was thinking inductor for some strange reason
Post by jeffc on Jul 7, 2015 11:36:05 GMT
Hi Chris, Can you please add 4 to your order for me. Even on SLA battery supplies that should be very quiet and that I've been using to play around with small and cheap Class D or AB IC-based amps and for supplying my Intel Atom motherboard/laptop HDD-based media player the ripple eaters seem to work some magic. Thanks.. jeffc
jc
Post by jc on Jul 7, 2015 18:15:01 GMT
Will do Jeff.
radius x4 boards jeffc x4 boards
jc
Post by jc on Jul 12, 2015 17:21:42 GMT
OK folks,
Order stands at 20 boards, assuming radius is still with us?
I will place the order in the coming days.
jc
Post by jc on Jul 20, 2015 15:55:13 GMT
Order ready to go, check your email!
jc
Post by jc on Sept 3, 2015 16:04:02 GMT
Boards are on their way to me, approx. 2 weeks.
jc
Post by jc on Sept 16, 2015 12:52:47 GMT
They're here! I ordered blue but received red, oh well, red it is then... I'll send out some emails when I get a moment or 3. If we could get hold of the Gerbers, maybe we could get the place Greg uses to do them another time? If anyone else is interested I did order a few spares (at my own expense).
