bullpup
Post by bullpup on Feb 19, 2015 23:43:31 GMT
Good evening
I have just dug out my HD580's and started to use them again after 5 years only to find that at medium volume or so I am getting distortion / crackling in one side. It is not a cable problem and it is not an amplifier problem.
Is this indicative of a capsule failure or is there somthing else I can look at?
Many thanks.
Post by PinkFloyd on Feb 20, 2015 10:53:06 GMT
Good evening I have just dug out my HD580's and started to use them again after 5 years only to find that at medium volume or so I am getting distortion / crackling in one side. It is not a cable problem and it is not an amplifier problem. Is this indicative of a capsule failure or is there somthing else I can look at? Many thanks. Try removing the pads and check that there's not a hair making contact with the driver
bullpup
Post by bullpup on Feb 20, 2015 12:44:20 GMT
Will do - thank you.
Post by Deleted on Feb 20, 2015 13:33:50 GMT
Just to be sure, pull the cables from the earcups, wipe clean and push back in.
Post by donunus on Feb 27, 2015 19:28:40 GMT
check the diaphragm whether it is crumpled or not. This happened to my first hd580s before. What you do is blow from the back of the cups. Blow it hard and quick and it will re inflate. Voila, distortion gone
bullpup
Post by bullpup on Feb 28, 2015 10:29:30 GMT
Thank you I will check.
Post by PinkFloyd on Feb 28, 2015 22:06:21 GMT
check the diaphragm whether it is crumpled or not. This happened to my first hd580s before. What you do is blow from the back of the cups. Blow it hard and quick and it will re inflate. Voila, distortion gone If that doesn't work........ do a handstand and BLOW into the cups with your left leg pointing toward Mecca and your right leg pointing west / south west.
jc
Post by jc on Feb 28, 2015 23:48:38 GMT
Have your needs changed then? When my 580s were turned into monos I replaced them with 600s. Still have those and use them. For closed I have the AKG K550 which is the best closed back I have ever heard BUT they are a very different flavour to the Sennys and are very pad-to-head-seal sensitive, some people just cannot get a decent seal (it' has quite large earcups) which makes them sound somewhat naff.
bullpup
Post by bullpup on Mar 1, 2015 10:14:53 GMT
Hi CJ,despite my assurances to the contrary, the problem turned out to be a clipping amp - defective psu.
However I need (ha Ha) a new set of phones with a degree of isolation. The 580's are mainly used for general listening, with sr225's for rock etc.
I liked the idea of hd 25's but they seem silly money.
I have a set of Beyerdynamic 990's but they are 600 ohm and I don't have an amp to drive them.
I have a larege head so I will have a look for the AKG K550's thank you.
